who can give diag on this one ?
i just installed my motor its been sitting for 2 years [ my battery is good ]when i turn the key i can here the starter beary turn over for 1 second then start clicking like the battery is weak but when i jumperd the 2 starter wires the starter turned the car over very well i thing something ground or purple wire can any one help with this one thanks very much............could a bad opti keep it from turning over..?
all contacts to the starter are good and the starter is new i took the purple wire loose form the starter and put a test light to it and it lite up very dim i put the test light on the large wire from the battery and it lite up bright i hope its simple. thanks againe for any input..
could be bad contact on a ground running to the engine, when i brought my car out of storage i tried turning it over and it would just make a clicking sound, when jumped it would start fine, i figured it out that it was a ground problem when i connected the black terminal on the battery to the engine (alt bracet, valve cover, ect.) and it would start up perfectly.
Sep 18, 2015 03:46 PM
