White smoke at high RPMs
Old Dec 6, 2003 | 10:12 AM
LtsRace's Avatar
This is a little of subject, but im trying to help my buddy out. Hes got a 2000 Mustang GT and hes having a problem with white smoke at high rev...any ideas what this is?
Old Dec 6, 2003 | 10:36 AM
ZDriver96's Avatar
white smoke = oil
High RPMs mean higher oil pressuremore load
So oil is blowing by something..
Oil is probably blowing by valve stem seals.
Old Dec 6, 2003 | 10:51 AM
Cmr0z28's Avatar
Originally posted by ZDriver96
white smoke = oil
Um......white smoke = coolant, blue smoke = oil
Old Dec 6, 2003 | 01:43 PM
Teal96TA's Avatar
My car did it on the dyno as well as an '03 Cobra w/ pulley and chip blowin' white smoke pretty good in the high revs.....was told it was probably something to do with valve seals but never got confirmation...
Friend said the Cobra did it because of the amount of boost.
Old Dec 6, 2003 | 01:58 PM
ibanez6rg's Avatar
I'm not sure but when theres fire, theres smoke
Old Dec 6, 2003 | 02:21 PM
bigde4u's Avatar
yeah i thought it was that way too!
Old Dec 6, 2003 | 02:50 PM
Cmr0z28's Avatar
I'll take a pretty educated guess here -- the cause is MOST LIKELY because um.....it's a FORD!
Old Dec 6, 2003 | 04:38 PM
Need4Camaro's Avatar
Call me dumb and all if I'm wrong, but I've had a simular problem only it didn't occur at high rev's... it was always there. Check your gaskets and sealings from any coolant linkage... Headgaskets in particular as they were my problem... If it turns out to be a gasket, depending on the serverity (which is probably low due to it only occuring at high revs when preasure is the greatest...) you can buy some sealing compound for it just to be budget wise... but if it's the headgaskets and they need to be replaced, tell your friend he better be ready to cough up some SERIOUS dough !
(total cost for me to have them replaced was like $2,500 + labor)
do it yourself and you'll knock off alot of cash.
Old Dec 6, 2003 | 05:07 PM
kcsoz20's Avatar
Exclamation
I agree with Zdriver96 My car does the same thing but only after load on the dyno and it is winding down. I will make a pull, high rpm's no smoke. I let out of throttle and a second later white smoke comes clouding out of exhaust.
It is white smoke and we walked into it and smelled it and it smelled oil smoke not coolant.
This was explained to me as during the pull, you are sucking a lot of air into the motor, duh! when you let off it creates a back vacuumn which starts to suck oil, most likely through the valves guides/seals.
During normal driving and track runs my car does not do this. Only on dyno.
Ken
Old Dec 6, 2003 | 07:28 PM
Teal96TA's Avatar
How can you check to at least kind of verify if its just pressure or if it is a coolant problem?
Old Dec 6, 2003 | 07:57 PM
S.J.S.'s Avatar
My old motor did it...my new motor does it. I'm wondering if it could be the back pressure from the valve cover breather that goes back to the TB?
Old Dec 6, 2003 | 08:54 PM
95CamaroZ-28's Avatar
Originally posted by Need4Camaro
...(total cost for me to have them replaced was like $2,500 + labor)
Wow, did they rebuild the entire engine? You could go all the way through an LT1 for $2500 in parts.
Old Dec 6, 2003 | 09:07 PM
dnz28's Avatar
what your seeing is a lite gray smoke, not white if you see white you would see it on start ups. the gray smoke is just excessive fuel burning off in the exhaust no biggy. I know some ones going to come on and say no that would be black, black is if your running rich. and is not being burned completely.
Old Dec 7, 2003 | 12:03 AM
93Z286Speed's Avatar
Grey Smoke = Fuel
Blue Smoke = Oil
White Smoke = Coolant
Game, set and Match
Old Dec 7, 2003 | 12:40 AM
Teal96TA's Avatar
One of my friends did say it could be fuel. My a/f ration was at 11.8 if that helps.
RUENUF
Mar 13, 2016 03:39 PM
ad356
Apr 11, 2015 08:49 AM
1996LT1Z28
Mar 8, 2015 08:16 PM
captcorvette
Mar 7, 2015 12:37 PM
