white smoke after injector swap
Old May 23, 2004 | 02:05 AM
TenaciousZ's Avatar
I just installed 30# injectors and my new pcm from madwolf and i'm getting a little white smoke. I wasn't getting this prior to the new injectors or pcm. car runs fine, no misses etc.. exhaust doesn't have a sweet smell to it. also it is kinda chilly out but anyone have any ideas why it I would have white smoke after the injector swap?
Old May 23, 2004 | 08:38 AM
Dave Feerst's Avatar
white sweet smelling smoke is coolant, unless you have puddles of coolant on your intake that drained into the engine with the injectors out i cant see how the 2 are related.
Old May 23, 2004 | 08:53 AM
TenaciousZ's Avatar
I couldn't tell ya, I just checked my oil and it looks fine, not milky. The smoke doesn't smell sweet at all. it's not thick or billowing or lingers. argh, I hate this.
Old May 23, 2004 | 10:07 AM
Fuels94TA's Avatar
Were the injectors new or used? Maybe they were treated with some cleaning chemical on the tips to prevent build up. Like when you go into a service for injector cleaner how all the smoke comes out the exhaust after they install that chemical treatment.
Vinny
Old May 23, 2004 | 10:07 PM
did you drop a can of seafoam in there?
black smoke is fuel, the one i would expect to see if you installed injectors that are too big.
Old May 24, 2004 | 06:40 AM
TenaciousZ's Avatar
not yet anyway, but I did find that the pcv tube on the passenger side valve cover was disconected and there is an exhaust leak before the 02 sensor. I connected the tube back and it only smokes a very little now.
Klypto
Mar 23, 2016 09:05 AM
RUENUF
Mar 13, 2016 03:39 PM
captcorvette
Mar 7, 2015 12:37 PM
dale3in98
Feb 14, 2015 12:18 PM
