whit smoke from exhaust/rich gas smell, and SES light after opti install
Old Dec 12, 2003 | 09:06 PM
Zack's Avatar
as stated in subject. I Could use a little 411 on whats going on witht he car
Old Dec 12, 2003 | 09:29 PM
Zack's Avatar
just great. I was out filling up the coolant, and it started surging, idle moving back and forth, then it dropped toi around 200
I hate this ****
Old Dec 12, 2003 | 09:49 PM
Spinner's Avatar
All of those sound like/point to a crossed wire somewhere.
Old Dec 12, 2003 | 09:52 PM
Zack's Avatar
plug wire? I dont see that being possible since I labled each wire and even triple check them when installing them
Old Dec 12, 2003 | 09:56 PM
Zack's Avatar
ok, im gonna make a little run down of whats happened since I finished the install. :
I started the car, it started, then shut off(stalled?) right away. I then placed a bttery jumper pack on it, and it started up and stayed on.
Now, while filling the oolant, and letting it wam up, white smoke is coming out of the exhaust. SES light on. I turned the car off to let the car cool because I had closed the Rrad cap because coolant was starting to flow out of it.
After letting it cool, i go to start it up, and it starts then shuits off again. I put the jumper back on it and it started, then after running it started surging, and idle dropped below 500. I shut it off
I went to go start it up again, check guages light on, SES light still on etc. CAr would crank over. I place the jumper back on it, it starts, then dies gain.
did I Say littlerundown? o
Old Dec 12, 2003 | 10:54 PM
Spinner's Avatar
Crossed plug = cylinder not firing = fuel in the manifold = burns there = white smoke and a bad running engine.
Gtpguy
Jan 26, 2015 04:50 PM
blac94Z
Jan 12, 2015 05:44 PM
Noenav
Dec 6, 2014 07:35 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
