While installing Roller Rockers.
Old Jul 19, 2005 | 06:18 PM
Black_Z28's Avatar
Ok, I have the whole TDC thing down, and all that stuff. But I'm stuck at setting zero lash and setting my pre-load. I have 1.6 SA Comp Cam Pro Mags and stock lifters. Do I tighten the rocker nut until I can't spin the pushrod or do I tighten it until there is some drag? I've heard some people say both. After that is it best to do a 1/2 turn? Or should I do more or less? Also, if I set #1 to TDC I can do In:1,2,5,7 and Ex:1,3,4,8; then to the rest when #6 is at TDC, right? Thanks a lot.
Old Jul 19, 2005 | 06:19 PM
Re: While installing Roller Rockers.
Adjustment reference.
Old Jul 19, 2005 | 07:02 PM
Black_Z28's Avatar
Alright, so you do just tighten until you feel some drag, then do a 1/2 to 3/4 turn on the nut. Sounds like a plan. Thanks for the help.
Old Jul 19, 2005 | 07:14 PM
30696bird's Avatar
As soon as the PR no longer turns freely, that is 0 lash. I would not turn it any more than half a turn after that. It will KILLLLLLL horsepower bad if you over tighten the rockers.
Nov 18, 2023 07:21 PM
dfarr67
Apr 10, 2015 07:44 PM
alliance12364
Mar 6, 2015 04:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
