wheres the fuel filter and how do you change it?
Old Jun 23, 2003 | 10:24 AM
chevyboy_z28's Avatar
wheres the fuel filter on this car, and is there any specific way to change it, or is it pretty much straight forward?
Old Jun 23, 2003 | 10:28 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
drivers side, jus before rear axel
strait foward
Old Jun 23, 2003 | 10:30 AM
Smoke T/A's Avatar
It's right in front of the rear drivers side wheel. It has a quick connect on one end and a threaded fitting on the other. Pretty easy to do. Just remember to relive the fuel pressure and wear eye protection.
Scream And Fly's Avatar
This goes without saying, but make sure you use two wrenches on each end at the same time, and loosen the old one very carefully. Don't overtighten the new one when you install it.
Greg
Old Jun 23, 2003 | 10:33 AM
I burn rice too's Avatar
This is easy but can be a little messy, the filter is on the drivers side near the rear tire attached to the back of the frame. First you'll need to crack open the filter with two wrenches and let the system bleed its self down, watch out for fuel spraying. Then all you gotta do is dis connect the side with nuts and press the clip in. Push it in and then push the clip in. That's it easy 10 minute job. Put something at under it first though and then go take a shower unless you like to smell like gas.
Old Jun 23, 2003 | 10:51 AM
Yeah, and make sure it doesn't bleed down on your face. Wear eye protection!
By the way, gasoline tastes aweful. Even washing it down with chocolate milk didn't help.
Greg
Old Jun 23, 2003 | 03:00 PM
Greg
It tastes even worse when you burp.
Old Jun 23, 2003 | 03:04 PM
treyZ28's Avatar
crazy radical idea-
as a good rule of thumb-
dont open your mouth when gasoline is pouring on your face.
actualy i'm going to extend that to a rule of hand and go so far as to say - if gasoline is pouing on you, close or pluh any hole possible. I have yet to find an organ in my body that appreciates gasoline...
and even further- if there is a chance gasoline might pour from it, dont go under it
.....rookies
Old Jun 23, 2003 | 03:47 PM
revtime's Avatar
Your not a true gearhead until you know what gasoline tastes like.
Old Jun 23, 2003 | 04:03 PM
hairbear21's Avatar
Don't forget the most basic part-loosen the gas cap (it will relieve the pressure) BTW, a TRUE mechanic knows what it feels like to have grease in the eye
Old Jun 23, 2003 | 04:12 PM
Z28chick's Avatar
The smell stays in your hair for days too... But I guess you GUYS don't have to worry about that as much.. heh
PCLZ28
Dec 24, 2015 05:19 PM
Alex Barnes
Jan 24, 2015 10:21 PM
Deadbolt24
Jan 19, 2015 01:29 PM
30thZ4C
Dec 26, 2014 05:09 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
