wheres the crankshaft pos sensor?
Old Aug 6, 2008 | 03:32 PM
clcam97's Avatar
yep just like the title says,my car started misfiring pretty bad so i had it scanned and got the CPS code,anyone has pics or sketches of where it is? thanks for any help
Old Aug 6, 2008 | 03:47 PM
It's on the timing cover, on the lower left as you look at the front of it. Normally, it does not cause misfiring, because it is not used for that purpose on an LT1. One can only assume from your screen name that you have a 1997.
http://shbox.com/1/engine_front_diagram.jpg
Old Aug 6, 2008 | 03:52 PM
clcam97's Avatar
my bad yea its a 97 camaro
Old Aug 6, 2008 | 03:55 PM
clcam97's Avatar
so whats the purpose of the CPS and what kinda problems my car could show?
Old Aug 6, 2008 | 05:11 PM
Used only to detect misfires. Some claim a faulty CKP sensor has made their engine run rough, but there is no logical reason for this to happen. You shouldn't notice any difference, other than staring at the SES light.
Old Dec 15, 2008 | 12:36 AM
IPrice's Avatar
Hey Fred,
Could a bad or faulty CPS cause a no start condition???
Curious.
Thanks,
Ivan
Old Dec 15, 2008 | 01:40 AM
Zeueses 97 RamAir's Avatar
have new one
if you need one i have new one ll sell you in box....
Old Dec 15, 2008 | 05:23 AM
As far as I know, its just used for misfire detection. Just make sure the code list you are using is not confusing the CKP sensor with the Opti optical sensor. I've seen lists that are misleading like that. Use Shoeboxes trouble code list.
14
Aug 11, 2015 12:03 PM
whitehooptie
Aug 10, 2015 07:02 AM
zajones
Jul 30, 2015 02:18 PM
mrwz28
Jul 8, 2015 09:11 PM
SergheiS
Jul 5, 2015 03:27 AM
