Where to tap into to install Autometer Temp gauge??
Old Aug 22, 2004 | 11:40 AM
No Cents Racing's Avatar
Where/how are you installing an autometer temp gauge?? Thanks for the help!!
Old Aug 22, 2004 | 12:42 PM
Re: Where to tap into to install Autometer Temp gauge??
Temperature of what? Oil, coolant, tranny?????? Electronic?
On an electronic install, the gauge needs its own sensor. You can't attach two gauges to a single resistance type sensor.... it would throw the readings of both gauges off. For coolant, you use the passenger side head port that is identical to the drivers side coolant temp port, but of course is located at the back, between #6 and #8.
Old Aug 22, 2004 | 04:28 PM
AWSOME!!! That is what we are installing!! Now, what about a mech oil pressure gauge???!!!!
Old Aug 22, 2004 | 08:15 PM
What year is your car? A "signature" with the basic info.... year, trans, any major mods.... helps people answer your questions without guessing.
If you have a 94 or newer, there is a plugged port on the block, right above the oil filter that you can use for a mechanical oil pressure gauge or for an electronic sensor. If you have a 93, you need to find a different location, because that's where the factory pressure sending unit is on a 93.
Old Aug 22, 2004 | 08:45 PM
Jon A's Avatar
Yup, right here:
http://www.jonaadland.com/Z28/Mods/O...r/PICT0010.JPG
99TransAmWS6
Feb 12, 2015 07:23 PM
cmdeshon
Dec 27, 2014 10:06 AM
brentbrowning01
Dec 16, 2014 06:35 AM
ro2207
Dec 4, 2014 06:18 PM
