where to start with oil burning problem?
Old Dec 7, 2005 | 08:34 AM
  #16
Fastbird93's Avatar
Re: where to start with oil burning problem?
Originally Posted by speedygonzales
Now the fun begins. The gapless rings (which I have) pull so much vacuum, unless you restrict the PCV system, you're gona pull oil into the intake.
Correct me if I'm misunderstanding you here, but wouldn't those actually help vacuum with a larger more agressive cam???
Old Dec 7, 2005 | 06:31 PM
  #17
Gary 95 Z28 M6's Avatar
any suggestions on rings then?
Old Dec 8, 2005 | 04:47 AM
  #18
Guest47904's Avatar
Guest
You're correct. That's exactly why I opted to use them.
Look here. http://www.federal-mogul.com/cda/con...1_6206,00.html
I would recommend sealed power brand. Contact summit racing tech line for suggestions on fitment.
Old Dec 8, 2005 | 05:32 AM
  #19
Fastbird93's Avatar
How well did they help out with your vacuum in relation to the size of the cam you put in???? This is just for curiousity's sake.
Old Dec 8, 2005 | 09:23 PM
  #20
Guest47904's Avatar
Guest
Used them a long time ago on a 327 and seemed to work well. The proof is in the longevity as well as the vacuum. As far as the newer engine. That is less than 2 years old, I never actually got the tird running since I ran out of money. Waiting on injectors, blower, tranny to handle the power as well as rear end. I'm not gona put it in till it has the blower. I won't start it till it has the tranny and rear to handle it.
blac94Z
Jan 12, 2015 05:44 PM
Scottylt1
Jan 8, 2015 02:48 PM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
