Where to purchase a new oil pump?
Old Jan 14, 2004 | 03:06 PM
DR.ZED's Avatar
94 LT1.
GM lists two different pickup assemblies, one larger than the other, but one oil pump.
Is this new information on LT4 vs LT1 differences?
Any suggestions on where to get a stock pressure stock flow oil pump? Is this a good dealer item?
Thanks in advance.
Old Jan 14, 2004 | 04:37 PM
Actually, they list 2 pumps and each has a screen that matches.
If you want the one with the larger pickup tube (.742 diameter), get
oil pump screen 12550042
oil pump 12555283
This is what was used on the LT1 1995-1997.
Old Jan 14, 2004 | 04:45 PM
DrewHMS97SS's Avatar
could go canton. but that intales a few other things
look over at racenet.net
Old Jan 14, 2004 | 05:04 PM
Camaro90RS's Avatar
What exactly does it entail?? I am doing a Canton pan and I am not sure which oil pump pickup I need.
Brian
Old Jan 15, 2004 | 07:39 AM
DR.ZED's Avatar
oil pump 12555283
Could this be why these cavitation issues are happening on pre 95 models?!?!?!?!?
Old Jan 16, 2004 | 05:28 PM
if i remember right, with the canton pan, all you have to do is get a mounting bolt. it has been a long while since i have read anything on the subject. check out racenet.net, they have all the info you need.
HectorM52
Jul 30, 2017 11:46 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Captain Kirk
Sep 8, 2002 01:47 PM
