where to lift on engine to pull pan?
Old Apr 25, 2006 | 06:36 PM
kyle97's Avatar
I'm going to be pulling my oil pan, and I'd like to make it easier by lifting the engine up a couple inches. I've got access to an engine lift, but i need some tips.
Where exactly should i attach my engine hoist? Would it be better to remove the tranny (M6) before i do this, or should i leave it in? If so, should I undo the tranny mount, or just remove the engine mounts bolts, lift up on the engine and hinge on the tranny mount?
Old Apr 25, 2006 | 09:33 PM
94zrag's Avatar
Re: where to lift on engine to pull pan?
Just un-bolt the motor mounts, the tranny mount will flex enough to not hurt anything. Also, when I pulled my pan, I had to loosen the bolts on the sub-frame and drop it a few inches so everything would clear.
Old Apr 25, 2006 | 09:36 PM
94zrag's Avatar
Oh yeah, you could probably take out a couple of the intake manifold bolts, and attach your hoist with some longer bolts.
Sandersen511
Jan 13, 2015 03:49 PM
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
formula218
Dec 2, 2014 04:27 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
