Where is the grounds on LT1?
Old Feb 8, 2004 | 05:36 PM
MongooseZ's Avatar
Just put in the 383.
Want to verify the grounds. Where are all the grounds?
One ground cable is the body one, flat copper.
Help!
Thanks.
Old Feb 8, 2004 | 06:07 PM
The only grounds I had to hook back up after having my engine out were the ones on the coil, from coil to LH frame rail (braided), the one by the knock sensor below #6 plug and battery cable ground on the front bolt of the RH motor mount bracket.
Old Feb 8, 2004 | 06:13 PM
MongooseZ's Avatar
Shoebox,
Please explain the one to #6 that one isn't ringing bells....
Old Feb 8, 2004 | 06:20 PM
Originally posted by MongooseZ
Shoebox,
Small stud for blk/wht wire from the harness that has the purple starter wire and knock sensor.
Old Feb 8, 2004 | 06:24 PM
MongooseZ's Avatar
Thanks Shoebox
I am getting a backfire through the intake and was told that not having the grounds right might do it.
I know the opti is on right.
The timing gear should be set up right.....
hmmmmm
Old Apr 6, 2005 | 04:07 PM
unTAmedLS1's Avatar
Re: Where is the grounds on LT1?
im getting the same thing... is there a way to test to make sure the pcm ground is actually grounding it
Old Apr 6, 2005 | 04:10 PM
WS Sick's Avatar
The best way to do it is to find the pinout diagram for the ECM, remove the harness plug from the ECM and then check continuity to ground at that point.
Injuneer
Dec 15, 2014 09:36 AM
Jul 4, 2005 05:00 PM
T/A lt1
Oct 10, 2002 03:14 PM
JSK333
Sep 9, 2002 10:33 PM
