Where to get heat tape?
I just did Lloyd heads and Jett Hott long tubes and i need some heat tape the keep some of my wires from burning. I checked at autozone and advance with no luck. Where can i get it? Thanks
You need "heat sleeves" not tape. The main thing is keep the wires, etc from touching the headers. Anything actually touching the headers will not last. So just making sure nothing is touching should do you ok.
You might consider sleeves in a couple areas though. And don't forget hoses, like heater,etc.
Sleeves can be expensive, so do a good analysis of just what and where you will need them.JMJO
Nayr
Mar 3, 2023 08:34 PM
CARiD
Sep 30, 2015 05:44 AM
