Where does this plug in?
Old Jul 16, 2009 | 04:21 PM
SmokeyBlaZe's Avatar
http://img217.imageshack.us/i/img0311geq.jpg/
http://img223.imageshack.us/i/img0311snt.jpg/
Old Jul 16, 2009 | 04:33 PM
..DAMN..'s Avatar
Water temp sensor?
MAF sensor?
Car wouldnt run without the maf sensor plugged in i think.
Old Jul 16, 2009 | 05:21 PM
You asked the same question in another post. I suspect the AIR pump.
Old Jul 16, 2009 | 06:39 PM
ok my air is disabled in the pcm so I dont guess i need to have it unhooked? Where about does it plug in?
Old Jul 16, 2009 | 09:46 PM
n2ceptor's Avatar
IF you look on the right side of the AIR pump you can see the plug.. Pic courtesy of Shoebox..
The harness connector for the AIR pump would plug into................. the AIR pump.
http://shbox.com/1/temp_sensor1.jpg
Old Jul 16, 2009 | 09:47 PM
n2ceptor's Avatar
What are the odds?...
Old Jul 16, 2009 | 09:50 PM
As Rob notes, the question was already answered.
https://www.camaroz28.com/forums/sho...36#post6040636
Old Jul 17, 2009 | 01:10 AM
guyette117's Avatar
looks like the mass airflow sensor plug
Old Jul 17, 2009 | 05:38 AM
The MAF sensor wiring is bundled with the ICM and coil commectors.
http://shbox.com/1/harness.htm
That appears to be the stand-alone harness for the AIR pump.
Old Jul 17, 2009 | 02:51 PM
meissen's Avatar
It's definitely the AIR pump. I had it left over in the harness when I did my LT1 swap and I did not put the AIR pump on my engine when I did the swap.
KYWes
Jun 14, 2022 06:52 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
Xiantyl
Jul 21, 2015 05:42 AM
