Where does this Ground go?
Old Jun 10, 2005 | 04:48 AM
unTAmedLS1's Avatar
OK the ground that is attached to the frame on the pass side where does it go from there?I have the pcm ground the motor mount ground but where does this one go to? I just put motor back in and im not sure where it goes
Old Jun 10, 2005 | 06:17 AM
Gripenfelter's Avatar
Re: Where does this Ground go?
Not sure which one you mean. Can you take a pic?
Old Jun 10, 2005 | 06:38 AM
Mystic97Z's Avatar
doesn't one ground to the motor mount, 1 for the starter, and 1 on the body up by the power steering?
Old Jun 10, 2005 | 08:50 AM
There isn't any other grounds on the passenger side that I recall.
Old Jun 10, 2005 | 03:38 PM
unTAmedLS1's Avatar
heres a pic of it sorry its the only pic I have and my car is at my friends on his lift so i couldnt take a new one yet.......it mounts on the frame rail by the sway bar mount on the pass side.....
http://tinypic.com/5v9afs
Old Jun 10, 2005 | 04:12 PM
Thats a weird one. Is it coming from your battery? Do you have your starter motor wired up?
Is it possibly an extra ground wire someone threw on for a better ground?
Old Jun 10, 2005 | 04:19 PM
unTAmedLS1's Avatar
no its just comin right off the frame I think it may go to my motor mount also maybe as an extra ground...If I put it there it wouldnt cause any probs right..?
Im trying to find a short. When I plugged in the battery I got a giant spark so I unplugged that fast
95chwagon
Oct 16, 2015 12:24 PM
autoxr166
Sep 25, 2015 04:21 PM
Greg88
Sep 20, 2015 07:14 PM
sleeperZ96BT
Sep 10, 2015 08:01 AM
92_RS_305
Sep 8, 2015 07:47 PM
