where does this go
Old Mar 18, 2004 | 12:06 PM
billygoat's Avatar
where does this go
http://shbox.com/1/1995_Z28_engine_harness_A4.jpg
cut and paste...
on the wire harness by the rh.o2 sensor and the wire going to the
starter, there is a little black wire labeled to ground on block or somthing like that where does this connect ive looked but hard to see under there
Old Mar 18, 2004 | 12:25 PM
HBHRacing's Avatar
there must be a stud or bolt hole in the bolt for that right near where the knock sensor is jusdging by the distence of the wire. any goof ground to th block will work. Sorry I can;t be more specific
Old Mar 18, 2004 | 12:30 PM
It goes here on a little stud below #6 plug, that is part of the fastening for the wire loom.
Old Mar 18, 2004 | 12:31 PM
madwolf's Avatar
There is a small stud and nut right near the dipstick, kind of in the middle of the block. You'll see it when you connect the starter wires.
If you still can't find it, let me know and I'll send you a picture.
EDIT: shoebox beat me to it!
Old Mar 18, 2004 | 12:32 PM
billygoat's Avatar
thsi helps alot thanks everyone
Old Mar 18, 2004 | 12:34 PM
billygoat's Avatar
and oh my the say somne idiot not to name names put that
balck on with the red to the starter would make the starter click instead of turn over properly?? dont worry ill chew this morons butt for this one haha
