Where do you have your cutout welded
Where do you have your cutout welded? I have pace setter LTs, ORY and the magnaflow CB exhaust. where would you reccomend that I have a cutout welded in. right after the header collecter, cut out of the Y pipe? What do you think, before or after the cat? Also, one or two cutouts?
:-d
:-d
Re: Where do you have your cutout welded
dual 3" flo-tecs just behind the collectors
It gave me 10 ft bls of torque vs capped on the dyno @ GForce. That was stock cubed, AFR-210s, custom ported LT4 intake, yada yada yada. With the 396 I'm anxious to see and hear the difference capped & uncapped.
Originally Posted by hulettsz28
Wow, 10ft pounds, thats quite a gain for a cutout. I think that I will go with one right after the collector, so the sound will be as loud as possible.
No clue on where to get it hosted. Do you think it would sound too raspy if i did it before the cat? Im thinking about not even using cats...i dont know.
suggestions
suggestions
suggestions
suggestions
Originally Posted by matLT1
Does having the dual cutouts behind the header rattle your interior to death?
I'm not mild, so I don't care basically, love the thunder and cam lope all in sync, especially at the track, was impressed with the torque gains and just flat out can't wait to here what it sounds & runs like with the 396 stroker and a solid roller .690+ lift cam.
Originally Posted by TransAm396
would it be possible to stick a bullit muffler in right after a pacesetter LT ypipe and a cutout RIGHT after it..then go to stock exhaust?
yeah it could be done.............just cut off part of the y-pipe too
If i went outside RIGHT now and cut off the back of my cut-out (end that is pointing towards the motor.........and cut off some of the y-pipe, there would possibly be enough room for a bullit muffler.
Try it, however..........the point of a cut-out is to be able to go from street legal to street lethal in a matter of a few bolts (or the flip of a switch)
However i drive with my cut-out off everyday and its not bad......i just pull a grandma off of lights (rarely EVER sees above 2k daily driving with the cut-out off........dont wanna attract too many cops........i.e.--illegal tint, inspection sticker just went out...and cant get a new one until my tint is compliant, and illegal exhaust)
but with it on its purrs through the stock cat-back..........sounds like a stock car with just a slightly better muffler, then when i get on it.......it roars nicely.
My advice..........just stick with the cut-out and no bullit muffler
Mine is on the back end of my off-road y pipe toward the muffler, which was actually perfect when I put in the electronic cutout plate the whole in the floor to go into the interior is right there.
Cam + Cutout is fun for those nights when you want to get noticed. Don't bother with two cutouts right after the collectors, the gains in my opinion would be minimal.
