Where do you get this tool
Old May 1, 2008 | 08:06 PM
jclark311's Avatar
I need those clips that go on the rocker arm and block the oil from squirting, while adjusting lifter preload, with the motor running.
Old May 1, 2008 | 09:02 PM
2QUIK6's Avatar
Summit has a couple of different ones
http://store.summitracing.com/egnsea...alse&N=700+115
But I found that the rockers still throw oil up. What I've done when I've had the covers off with it running was cut out a piece of cardboard that runs the length of the rockers and curves up at each end and just placed it between the rocker tips and the raised edge of the head and the springs.
Nice and cheap and keeps the oil in and you can make one right now instead of waiting for the clips.
Old May 1, 2008 | 09:56 PM
The tool is called heavy duty aluminum foil.
Old May 1, 2008 | 10:12 PM
user 647483's Avatar
Old May 2, 2008 | 02:28 AM
jclark311's Avatar
I think i will try the clips!
Old May 2, 2008 | 02:57 AM
SS RRR's Avatar
Autozone should have clips.
marlar98
Sep 12, 2018 07:18 AM
mlopezart
Sep 8, 2015 12:15 PM
AtlasXVIII
Sep 7, 2015 03:39 PM
Aug 24, 2015 06:41 AM
4586
Aug 22, 2015 01:09 AM
