Where do the OPTI vents go!?
Old Oct 18, 2008 | 11:05 PM
LT1Zcar's Avatar
I just installed a new distributor and water pump on my 1994 camaro z28 and it had previously been converted to the vented 95+ style, i have the set of two small hoses, one that goes into the intake elbow, and the second that goes?????? Does it just hang free? I can't find where they each go to. HELP.
Old Oct 18, 2008 | 11:09 PM
user 647483's Avatar
Old Oct 19, 2008 | 07:02 AM
Probably easier to see the details if you go to the full-size version.
http://shbox.com/ci/opti_vent.jpg
http://shbox.com/1/opti_vacuum_hose.jpg
http://shbox.com/1/opti_vacuum_conn.jpg
http://shbox.com/1/opti_vacuum_harness.jpg
Since you have a 94, you will have to drill a small hole in the intake elbow to poke the blue 90-degree air supply line elbow into. And you will not have a "free" vacuum connection on the driver's side of the intake manifold, unless you have deleted the EGR vacuum line. If you still have the EGR vacuum line connected, just put a "tee" in that line to connect the Opti vacuum line to.
For all your info needs on the LT1, use Shoebox's website. If you haven't been there yet, go there and take a look around:
http://shbox.com/1/4th_gen_tech1.html
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
94Maroz28
Oct 27, 2015 04:38 PM
colts0455
Sep 27, 2015 01:07 PM
tdigger9899
Sep 7, 2015 10:56 AM
