Where do I get a 400 Balancer for my 383 LT1????
Old May 18, 2006 | 04:28 PM
Mike96z's Avatar
I need to get a balancer that will bolt up to my 383 Lt1 so that I can have it balanced. I can't find one anywhere, anyone here have a 383 and can tell me what to do because my engine is about 300 grams off in the front and I need to use the 400 balancer if I can find one. The LT1 balancer is too light.
Old May 18, 2006 | 04:43 PM
WS Sick's Avatar
Re: Where do I get a 400 Balancer for my 383 LT1????
What crank are you using? I have used the neutral balancer (after balancing) on both the Eagle and the Scat cast steel cranks.
Actually it's a neccessity to get it neutral balanced in the font, it may cost a little more on the balancing, but it saves some headache.
Old May 18, 2006 | 04:59 PM
rob97ss's Avatar
I used the stock balancer with a scat crank,it did cost a few dollars more to balance,but works fine......
Old May 18, 2006 | 05:17 PM
lethal93ta's Avatar
it sounds like you got the wrong crank, you should have got an internal balance crank, 300 grams is a lot, I had to add 42 grams to the front of mine and 86 to the back and thats a big slug I had to put in there.
Old May 18, 2006 | 05:28 PM
Mike96z's Avatar
I got the eagle cast steel crank 1 piece seal internal balance crank, maybe I was sent the wrong one or something? It was from summit and I have a T-56. I was thinking they could fill the balancer with wieghts and then what's left put into the crank. I think I got the right one, everything fits and it's internally balanced with holes drilled etc.
Old May 18, 2006 | 05:32 PM
Mike96z's Avatar
Well here's the link, right crank. http://store.summitracing.com/partde...orig=1&FROM=MG and I'm using PM Rods and Hyper pistons which might be the reason it's so light on the front end. So what's my best bet?
Old May 18, 2006 | 06:26 PM
RE AND CHERYL's Avatar
Sorry, but you have an external balance crank. It may say internal balance, but this is the last line in the item overview.
Notes: Requires Chevy 400 harmonic balancer and use of stock flexplate.
It probably has enough weight in it to not need the ofset weighted 400 flexplate, but it still needs the 400 style balancer. Unless you can get a custom balancer made, your screwed. No way you can make that work in an LT1.
Old May 18, 2006 | 07:12 PM
lethal93ta's Avatar
yep hes right it says you need a 400 balancer and no one makes one for a LT1.
Old May 18, 2006 | 07:37 PM
Mike96z's Avatar
Well if there's no way why the hell does summit advertise as:
Stroker Crankshaft Yes
Make CHEVROLET
Engine Type V8
Liter 5.7
CID 350
Engine Size 5.7L/350
Beginning Year 1992
Ending Year 1997
Engine Family Chevy small block Gen II (LT-based engines)
Rod Length 5.700 in.
Crankshaft to Flywheel Attachment 6-bolt
Application Notes Fits stroker applications only.
and If this won't work, where can I get a true Internal balanced crank for the LT1 from eagle or whoever that will work with the stock balancer, I'll just ship this one back to summit and buy the other one.
Old May 18, 2006 | 07:45 PM
Mike96z's Avatar
I think summit has the wrong description just like alot of their items, found the same item on ebay, same part number etc. and it says
http://cgi.ebay.com/ebaymotors/Chevy...QQcmdZViewItem
Use 350 balancer. but this part number on summit says 2 pc seal and he claims 1 pc seal.?????????? WHo's wrong here?
Old May 18, 2006 | 08:06 PM
Mike96z's Avatar
This is the only other crank that I have found that's even close to what I need but claims to be only for gen 1 cars til 86, all the specs seem the same though, who knows, I don't think I can trust summit anymore.
http://store.summitracing.com/partde...5&autoview=sku
Old May 18, 2006 | 08:07 PM
Mike96z's Avatar
Whatever you guys used, please let me know, whoever used a cast steel crank, post a link to the crank you used and I'll just buy that one so that I don't have to go through hell. Thanks
Old May 18, 2006 | 09:47 PM
Joe Brodman's Avatar
GP Moderator
I used a Lunati 1 piece rear main seal internally balanced crank forged crank. Though I'm told it wasn't very well balanced from Lunati and required a decent amount of work.
Old May 18, 2006 | 10:32 PM
Kevin Blown 95 TA's Avatar
I used the Lunati Sledgehammer cammed for 5.7" rods (which was a mistake on my part cause I have 6" rods) and that metal they took off to make it fit the 5.7 rods cost me a lot in balancing, but they ground off metal in the right place and added 1 piece of heavy metal and it is a beautiful job which works with a neutral flexplate & balancer. here's a pic of it all done up - you can see where they took off metal rather than add a lot of mallory...
Old May 19, 2006 | 03:21 AM
Mike96z's Avatar
so since my crank needs 300 grams in the front and the rear is the heaviest part, they could just take alot of metal out to even it up more and put in less heavy metal?
