where is the cheapest place to find these parts
i have decided to go ahead and do the cam swap. but i need to know where is the cheapest place i can find these parts.
36 lbs injector(recommend a brand that is good while you at it)
58 mm throttle body(i know, i just missed that gp)
comp r lifters
comp pro magnum 1.6 roller rockers(NSA)
Guide plates(GM part # 14011051)
7.2 hardened push rods
95 impala head gaskets
cloyes true roller timing chain
also i wont to go with a high flow mellings oil pump. or do you think this is smoenthing that i dont need.
thanks for all the help.
comp r lifters
Re: where is the cheapest place to find these parts
www.gmpartsdirect.com for the Impy head gaskets and guide plates. The rest of that stuff I would just look for on here, alot of it turns up all the time. Also I would stay away from the high volume oil pump.
Originally Posted by duckhead4life
why wouild you not get the high volume oil pump
10-31-2016 11:09 AM
