Where can I get new 'Banjo' bolts for my heads?
Does anyone know where I can get two new 'Banjo' bolts for my 93 Z28? I chewed the stock ones up trying to get them off my heads and I really need some new ones before I can get my car back together.
yeah, the stealership...btw, I HIGHLY recommend replacing the washer gaskets as well, you can just use oil pan plug washer gaskets....unless you want to pay the $7 a piece the stealership wanted to charge me.
Good point that you will want to get new seals, too.
1993-1997 coolant steam pipe seals
GM p/n 10108689
You will need a total of 4 seals.
If you buy from Jason or Dal, it will be half the price of your local dealer. When I got my 2 bolts and 4 seals from Dal a while back, I spent ~$21 on them.
GM p/n 10108689
