Where can I get a good crate motor??
Old Jul 12, 2003 | 09:54 AM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
I'm looking to spend under $3500. Low compression for the S/C. Are the crate 350 motors the same as the LT1? Does it matter. I'll be dropping all emissions anyway. Thx for the help.
Old Jul 12, 2003 | 11:59 AM
Zjoker's Avatar
sdpc2000.com try these guys
Old Jul 12, 2003 | 12:11 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
www.cmotorsports.com
Old Jul 12, 2003 | 03:03 PM
DJ:BOTA's Avatar
Will this motor work with my application?
Old Jul 12, 2003 | 03:41 PM
treyZ28's Avatar
it is not an LT1 so many of your accessories and you pcm and such will not work...
the lack of an opti will be your first problem (or saving grace?), you will need a new intake manifold, water pump, distributor, carb or pcm, as well as a few other things i missed
Old Jul 12, 2003 | 07:44 PM
DJ:BOTA's Avatar
Ugh, that's not going to work. Thx bro.
Old Jul 13, 2003 | 11:53 AM
95 WHITE TRANS's Avatar
Try nu-tek motorsports you reach them at
www.nu-tekmotorsports.com I hope this can help you out.
NICK
Old Jul 13, 2003 | 12:52 PM
96 WS6's Avatar
cmotorsports or nu-tek.
I think Bret Bauer is doing a NICE short block GP right now.
Old Jul 13, 2003 | 01:18 PM
White_94_TA's Avatar
Could always just buy an LT1 Shortblock.
paceparts.com has a LT1 Crate for 4500.. LT4 Crate for 5500
Old Jul 13, 2003 | 01:32 PM
pennys58's Avatar
http://www.goautocenter.com/
Try these guys, they're really not that bad and customer service is really good.
You can get the LT1, LS1, and the LS6. Pretty much with any option too.
John
Old Jul 13, 2003 | 07:43 PM
DJ:BOTA's Avatar
John
They look priced reasonable.
Old Jul 13, 2003 | 10:35 PM
Van5150's Avatar
The prices look good, and the power looks ok, but those numbers are flywheel hp. Those will not be the numbers you pull when installed in your car at a dyno.
Old Jul 13, 2003 | 11:46 PM
DJ:BOTA's Avatar
I'll have them adjust it so I car run some boost. Power is a belt away!
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
hotrodyou1
Dec 20, 2014 10:05 PM
nballisru
Dec 14, 2014 05:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
