where to buy o2s, extensions, header gaskets?
Old Aug 6, 2010 | 01:43 AM
SkiBumDreams's Avatar
first off i have been trying to find the best price on ac/delco/delphi o2 sensors, does anyone have any leads?
as far as the extensions go i have found them at jegs, summit, and speed inc. does anyone have any other options. i have thought about making my own extentions but i dont have any leads on where i could find the proper connectors and pins. i am fully capable of making them myself, i would rather not splice into the engine harness if i dont have to.
finally the header gaskets, i am thinking of going with percys seal for goods seeing as those seem to be the best sealing. i have only been able to find them available directly from percys website. are there better sealing out there?
i have searched through all the supporting vendors on the site and i couldnt come up with anything about these items. i have also searched old posts and cant find much in the way of this type of info on where to find these items. thanks for any input and have a good one.
Old Aug 6, 2010 | 11:09 AM
lildemars09's Avatar
Try streetsideauto.com i find some really good parts on there and fast shipping. i believe thats a really good site for some parts. check that site out and let me know. if u want to buy something, heres a coupon that u can use to get 10% off...save10, type that in the checkout box
Old Aug 6, 2010 | 11:55 AM
Shoebox has a couple links to cheap GM parts (O2's):
http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason
Old Aug 17, 2010 | 10:32 PM
Been continuing my searching and my best place for o2s is through my cousin who works at a local autoparts store and can get me delphis.
now for those interested in making their own extensions i found a site that sells connector kits as opposed to a lot of connector sites where you have to pair the connector with the proper pin with the proper boot etc. here is a link to the connectors i believe are the same as the flat 4 pin o2 connectors.
http://www.bmotorsports.com/shop/pro...roducts_id/753
http://www.bmotorsports.com/shop/pro...roducts_id/700
are these correct?
this site also has tons of connector kits even some opti harness related i saw.
another question comes to mind: what about the actual wire to use in the homemade extensions. what should i be careful to watch for like gauge etc? any recommendations?
i only link to these because i could not find these things under any of the site sponsors, if site sponsors do have these i would gladly buy from them.
Old Aug 19, 2010 | 01:54 AM
Jon_Esslinger's Avatar
I got mine at Speed Inc. since they're nearby. Thunder Racing has a lot of good wiring stuff usually.
Queens94z28
Dec 20, 2014 09:11 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
bee20e
Parts Wanted
Nov 27, 2014 05:20 PM
thenewkid
Nov 27, 2014 09:41 AM
