where is the airbag module located?
Old Mar 23, 2004 | 10:50 PM
93formula's Avatar
does anyone know, thanks
Old Mar 23, 2004 | 10:52 PM
Red96Lt1's Avatar
Are you talking about the one under the console?
Old Mar 23, 2004 | 10:55 PM
Kevin_97's Avatar
There is one under the console, and then I think three other sensors. But I'm not sure where they are exactly...
Old Mar 23, 2004 | 11:09 PM
The arming sensor is under the console.
There are two discriminator sensors: one in the upper dash, just to the right of the steering column support bracket and the other is right by the hood latch. The DERM is behind the glove box.
Old Mar 23, 2004 | 11:27 PM
Red96Lt1's Avatar
Ok Rob you got me curious now. What do all of those do? And what is DERM?
93formula's Avatar
which one is needed when you replace the airbags? the one under the center console? whichever one goes is the one i need to find. thanks
ps not my car
Old Mar 24, 2004 | 08:55 AM
Diagnostic Energy Reserve Module ( the brains ) Monitors the system and provide reserve power to fire the air bags if voltage is lost during a collision.
The arming sensor closes at lower velocities than the discriminating sensors, to make sure that voltage is supplied to the air bags.
The discriminating sensors are the ones that really "feel" when you have a crash and provide a ground path to fire the bags.
There are no components that are mandatory to be changed after air bag deployment on our cars (unlike some others). Of course, any component that was in the damage area should be replaced and not reused.
A diagnostic of the system after all has been put back to normal might be a good idea.
Old Mar 24, 2004 | 08:52 PM
93formula's Avatar
oh so you dont need to replace the module?? thanks.
Old Mar 24, 2004 | 10:47 PM
That's what the factory manual said.
beltrunner
12
Jul 15, 2015 08:39 PM
Scorch1
Jun 30, 2015 11:24 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
Lakebratt
Feb 5, 2015 07:55 PM
bsmith
Jul 19, 2002 06:08 PM
