When Will It Stop!!?
Old Feb 28, 2004 | 09:14 AM
SlickLT1's Avatar
Ok, My stock 94 Z is acting up once again. The car is missing very badly upon acceleration. I also hear a little tick coming from the drivers side cylinder bank upon any more than a creeping acceleration. The car runs fine at some times, and like sh!$ at others. Today I took it out, it was cold out, and I couldnt get the car to drive without having a bad shutter. The car is not revving unusually like before I did the opti. I cant figure this one out. Im going to take it to a dealer and get it scanned. But does anyone have any idea whats up? Thanks guys Cory
Old Feb 28, 2004 | 07:27 PM
OBE1 95Z28's Avatar
Look under your hood in the dark while the engine is running and see if you have a "light show". The ticking sound could be a bad wire causing the spark to jump to the exhaust manifold or block. This would cause your car to run on 7 cylinders.
Old Feb 28, 2004 | 08:22 PM
z28marine's Avatar
could be a spark plug wire if loose on the plug. i had the same problem...popped it back on, no more shudder
Old Feb 28, 2004 | 08:28 PM
Transamdriver's Avatar
You either burned a wire or it fell off would be my first guess.
Old Feb 28, 2004 | 10:34 PM
SlickLT1's Avatar
wow...I feel really stupid. It was a plug wire. Thanks for your help guys.
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
4586
Sep 27, 2015 01:55 PM
KYWes
Sep 26, 2015 08:49 AM
mark0006
Sep 14, 2015 12:35 PM
Aaront810
Sep 11, 2015 11:24 AM
