When I hit a bump, my interior light turns on...
This just started happening... when I hit a hard bump, one or all of my interior lights will flash on and then fade away slowly. I know the hatch light is burnt out but what could make that happen? It's annoying drivin down the road and then hit a bump and have the light flash on.
Yep you need to adjust those rubber stops for your hatch. Just turn them out a turn or two and try it. It must be just lifting enough to release the light switch..
EDIT: To verify its your hatch just walk around behind it and lift up on the spoiler while its closed and see if the light comes on..
F'n1996Z28SS
Aug 23, 2023 11:19 PM
squarehead
Nov 21, 2014 08:02 PM
ford
Aug 3, 2002 02:39 PM
