when driving in D, I floor it and car flies, then let off gas, RMPS down, then no go
Old 03-27-2003, 11:50 AM
sc93's Avatar
So when I let of the gas coming off a 0-50 mph romp, the rpms start going down slowly, then the drop suddenly to idle RPM's. Then when I slow down and press the gas, engine revs but doesn't want to go anywhere. Almost like the tranny isn't grabbing if that makes sense.
This is a 93 Z28 700R4/4L60 btw. 3.23 gears
Also, the shift points are low. In OD at WOT from a stop I floor it, and it goes to 4500 rpm and then shifts. Doesn't go to redline.
Any ideas?
sc93 is offline
Old 03-27-2003, 11:54 AM
Kris93/95Z28's Avatar
Re: when driving in D, I floor it and car flies, then let off gas, RMPS down, then no go
Any ideas?
Might be your govenor in the transmission.
I know when my transmission was rebuilt the govenor needed to be adjusted because the car would shift at a very low RPM about 4,500~5000 at WOT.
For the low idle deal, my 93 would do the same until I replaced the Idle air control valve....That really cleaned up alot of problems
Kris93/95Z28 is offline
Old 03-27-2003, 12:06 PM
Gripenfelter's Avatar
Sounds like your Throttle Position Sensor or TV cable.
My TPS was shot and my car would shift at 5200rpm instead of 5750rpm.
I put in a new one and it shifted at 5800rpm.
Clean your IAC while you're at it.
Gripenfelter is offline
Old 03-27-2003, 12:23 PM
sc93's Avatar
Ok thanks for the input.
Where are the TPS and IAC located? Can I change these myself?
sc93 is offline
Old 03-27-2003, 12:32 PM
The TPS is the black semi-round plastic piece on the passenger side of the throttlebody held on by two screws.
The IAC is on the bottom of the throttlebody. You will have to remove the throttlebody to get at it.
Piece of cake.
Old 03-27-2003, 06:57 PM
12SCNDZ's Avatar
You're input sprag inner race lugs are broke.
Your TPS has nothing to do with your transmission. It will only affect a 4L60E equipped car, which is electronically controlled. Your car has a 700 which is TV, and governor controlled.
12SCNDZ is offline
Old 03-27-2003, 07:42 PM
sc93's Avatar
input sprag inner race lugs ???
please explain, I've never heard that before.
What do they do? Where are they? How do I replace them?
sc93 is offline
Old 03-27-2003, 09:30 PM
Tranny innards. Unless you can rebuild the tranny, you need to take it to shop.
shoebox is offline
Old 03-27-2003, 09:31 PM
sc93's Avatar
thanks, that's what I figured
sc93 is offline
Old 03-27-2003, 09:34 PM
sc93's Avatar
Is there anywhere I can get a repair manual for the 700R4 (4L60) ? I am interested to see expanded views of internal components and such, to see how the thing works, and where everything is.
sc93 is offline
Old 03-27-2003, 09:39 PM
A factory manual will tell you everything you need to know.
shoebox is offline
Old 03-27-2003, 10:28 PM
GPZ1100's Avatar
All the more reason
to get a stick shift next time! (couldn't resist).
I had similar issues with my old boat (an 84 taxi cab).
Car would granny shift, at WOT, the revs never got above 4000 rpm (84 vintage, 305 with 700r4), etc etc.
I got so fed up with it, i swore that would be the last auto i'd ever get. Been driving manual since.
GPZ1100 is offline
97SSdude
12-31-2014 07:43 PM
Red97LT1
9
12-17-2014 06:13 PM
The Seer
Classic Engine Tech
11-26-2014 05:55 PM
USAirman93
11-24-2014 03:37 PM
BIGCOWL-IMP
11-21-2014 09:40 AM
Quick Reply: when driving in D, I floor it and car flies, then let off gas, RMPS down, then no go
