When does size matter ?
Old Mar 23, 2003 | 02:40 AM
bowtiepwr's Avatar
>Atleast in header size ?
I am using Hooker Long tubes (#2231) which have primary tubes of 1 3/4" So when should you step up to bigger size 1 7/8" or 2" primaries ?
BTW this is for a LT1 396cid supercharged .
Also who makes a good 1 7/8" or 2" LT1 header ?
Old Mar 23, 2003 | 01:18 PM
Just a thought, but one of the most powerful LT1's (1,125HP) used 1.75" Hooker LT's. For the next engine to go into that car, at about 1,300HP, he is running custom made 2" primaries. Both engines are 383's with Vortech blowers.
Might give you an idea of the info you are looking for.
In any case, this belongs on LT1 Tech, not on Advanced Tech. Moving......
Old Mar 23, 2003 | 01:33 PM
Mindgame's Avatar
Don't know anyone who makes a 1-7/8 for the F-body. You'll have to go to a custom outfit like Rewarders, Lemons or build your own.
Just to give you another idea...
I built a 383 some years ago for a 66 Nova bracket car. At that time I was running a 1-3/4 Hooker header. That engine dynoed at just over 600 hp and 510 lbs-ft of torque. She dropped a valve and while I had the engine out for repairs replaced the Hookers with a set of Stahl 1-7/8 unequal length headers (never seen gains from equal length)... the engine picked up an average of 7 lbs-ft in the midrange (right where each shift landed me on the rpm drop) and picked up a very consistent 3 tenths and 2 mph at the track.
-Mindgame
Old Mar 25, 2003 | 05:47 AM
bowtiepwr's Avatar
-Mindgame
>How do you get a hold of these company's ?
Old Mar 26, 2003 | 05:05 PM
Mindgame's Avatar
http://www.lemonsheaders.com/
http://www.rewarderheaders.com/
If you ever decide to try to build a set (as I am) you might want to check out Burns stainless, Headers By Ed and Stahl. They all make the mandrel bent tubing and collectors. Burns has a neat website... well worth checking out.
http://www.burnsstainless.com/
-Mindgame
93 RedBird
Nov 15, 2015 08:24 AM
RX Speed Works
Oct 1, 2015 10:19 PM
colts0455
Sep 11, 2015 06:16 PM
RobFlag
Aug 29, 2015 11:40 PM
Z28amustangklr
Jul 18, 2015 11:05 AM
