When to do 4 bolt main conversion.
The question is probably been asked many time but I couldn't find any info. I have a forged short block but it has a 2 bolt main. I'm looking for about 800HP so should I get it converted to 4 bolt and splayed? How much does it typically run?
Re: When to do 4 bolt main conversion.
I would say that you will need a 4 bolt setup for that but many factors help make the decision.
I'm assuming you will be using a major power adder to get 800 HP so its safe to assume that you will need a 4 bolt setup.
RPM is also a major factor in the decision.
I'm not even sure that the stock block can handle 800 HP on a regular basis.
I imagine that others with more experience than I will be of more help.
For an 800HP setup, 4-bolt mains would be a good idea. The stock LT1 block, with the 4-bolt caps, has been demonstrated to be very reliable, without block fill, at power levels in excess of 1,100 flywheelHP.
800 HP is a really big number. With a 3050 lb car, I wouldn't think that you would need 800 to get into the 9's, but I could be wrong. I would imagine with a quality, purpose built turbo motor wouldn't have a problem running a 9.99. I'm sure that the gang over on the Forced Induction forum would be able to get you pointed in the right direction for your combo.
