wheels aren't chirpin!!!!
Old May 12, 2006 | 03:05 PM
DontMixWithRice's Avatar
I just dropped a lt1/t56 combo, and i have no low end power...i cant, for the life of me, get the car to spin the wheels...even if im rolling at 10mph on first gear and slam the gas...nada.
engine is stock expect for full intake/exhaust/lt pacesetters/255 walbro pump.
Old May 12, 2006 | 03:36 PM
94CamaroZ28's Avatar
Re: wheels aren't chirpin!!!!
Um. gears, tires, tuning issues, any codes, crispy clutch?
Old May 12, 2006 | 03:37 PM
Z28LT1_Just_Nasty's Avatar
Traction control?
Old May 12, 2006 | 03:40 PM
easyc4's Avatar
make sure ur torque arm is on tight at the tranny, and check the tranny mount, and the lca bushings and make sure all thats kosher
Old May 12, 2006 | 03:53 PM
jsetzer's Avatar
Bone stock? Its not going to do much roasting from a roll with any sort of decent street tire.
Old May 12, 2006 | 04:38 PM
MeanGreen97Z's Avatar
I bet it was a 2.73 rear end car and now has a T56! You'll get awesome gas mileage!!
Old May 12, 2006 | 05:12 PM
chas's Avatar
My stock 97 Camaro will spin like crazy even if i am 50% WOT. I have Toyo
18- 35- 295's on the back! As far as i know it still have the stock 2:73 rear gear, hate to see what 3:73's will do for the spinning.
Chas
Old May 12, 2006 | 06:35 PM
JimboManJones's Avatar
Thats funny, most guys are trying to get traction, and you are trying get wheel spin.
Old May 12, 2006 | 11:33 PM
Chopstix's Avatar
it is an ex V6 car....he says it is an RS....should have 3.08 gears but open diff...
Old May 12, 2006 | 11:44 PM
slow95camaroz28's Avatar
shift faster haha, just kidding you might need a tune.
Old May 12, 2006 | 11:56 PM
snakeatinZ's Avatar
is your floor mat cramed under your gas petal?
Old May 15, 2006 | 08:13 AM
tuning issues---the computer is all obd1 and its tuned properly...
any codes---nope! clean as a whistle!!!
crispy clutch? new clutch
the rear is a 3.42.
i dont know what it could be. the tranny mount is a brand new poly urathane. the lca's are off the v6 and the torq are is in there tight!
any other suggestions?
Old May 15, 2006 | 08:22 AM
LT1Formulation's Avatar
Clean your MAF. I had an LT1 Caprice that was a dog even after a tune, turned out the sensor was coated with K&N oil. Took some electronics cleaner and sprayed it on a Q-tip, then gently cleaned the inside of the MAF. Man, that woke it up! It would spin the tires HARD! Try that...
Old May 15, 2006 | 08:41 AM
Javier97Z28's Avatar
Moderator
get a honda
Old May 15, 2006 | 08:52 AM
Originally Posted by Javier97Z28
get a honda
JUST MIGHT....
