What's your total timing????
Old Sep 27, 2005 | 07:55 PM
AF96Z28's Avatar
I'm wondering what everyones total timing is. I think I may have a little too much advance. I'm set at like 46* WOT @ 6200 rpm. Plus I'm trying to get a good gauge for pulling a couple degrees out for the juice. Any help would be great.
Thanks,
Jeremy
Old Sep 27, 2005 | 08:04 PM
turbo_Z's Avatar
Re: What's your total timing????
Id shoot for about 10 degrees less than that at 6200.
Old Sep 27, 2005 | 08:20 PM
AF96Z28's Avatar
I thought it seemed a little high. You think I should pull that much timing throughout the curve?
Old Sep 27, 2005 | 09:56 PM
1racerdude's Avatar
Get a MSD timing retard box and pull 2* for every 50HP shot.
Old Sep 28, 2005 | 03:12 AM
sssalah's Avatar
That's too much timing considering you're running a bigger cam. At high rpm the bigger cam could stuff more air in the cylinder creating more cylinder pressure and that requires less timing. On the same line because big cams with healthy overlaps bleed pressure at lower rpms it is necesury to have more advance there.
For the Juice I used to have the Mallory 685, which has good features like retard, window switch...etc.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Cam's maro
Dec 28, 2014 09:30 AM
Dec 4, 2014 11:56 AM
centric
Aug 15, 2002 09:04 PM
