What's wrong with my car? Please help.
Old Nov 7, 2003 | 10:04 PM
Ronin's Avatar
My 93 Z28 was running rough and would not rev over 1500 rpms. It would start to bog and lose rpms. It would idle smooth and does not smoke. I figured it was the opti and just finished changing it. I also added a new water pump. The car runs the same now as it did before. Any ideas what is wrong? It seems like it is not getting enough fuel. Has this happened to anyone else? If you think you might know what's is wrong please post.
Thanks for the help.
Old Nov 7, 2003 | 10:25 PM
badazzcamaro97's Avatar
I had the same experience on my 85 Firebird. on it, it turned out to be the computer itself. I know it wasn't an LT1 but just a suggestion.
Old Nov 7, 2003 | 10:26 PM
Blu85ROC's Avatar
MAF, maybe? I'm no expert but a similar thing happend to me when my MAF wasn't totally pluged in (on my IROC), maybe it's bad. Just a guess. Hope it helps
Daniel
Old Nov 7, 2003 | 10:30 PM
LSUxBlake's Avatar
sounds to me like the MAP sensor on top of the intake manifold.....
Old Nov 7, 2003 | 10:32 PM
Ronin's Avatar
Hi guys, I forgot to post that I tried changing the chip to a Hypertech alone and then piggyback on the stock chip. I also changed the fuel filter. I think it may be the TPS or cat is clogged.
Anyone other ideas? Thanks
Old Nov 7, 2003 | 10:36 PM
Blu85ROC's Avatar
I though a bad TPS would make it idle erratically Just curious though.
Old Nov 8, 2003 | 07:43 PM
Ronin's Avatar
Today I changed the TPS and MAP sensor. Still runs the same. Tommorrow I may drop the y-pipe and see if the cat was clogged.
Any other ideas? Thanks
Old Nov 9, 2003 | 01:39 AM
JDBlaze85's Avatar
whats the fuel pressure at?
check 02 sensor readings while engine is bogging.
Old Nov 9, 2003 | 01:40 AM
JDBlaze85's Avatar
pull your fuel filter down and blow through it. see if its clogged. a bad filter will make the car run like ***.
Old Nov 9, 2003 | 02:33 AM
speedracer93z28's Avatar
when this happened to me, my cat was clogged
Old Nov 9, 2003 | 03:02 AM
93formula's Avatar
same here, clogged cat, but it got progresivley worse. did you sense something was amiss leading upto this?
Old Nov 9, 2003 | 04:34 AM
Fullagar's Avatar
Well since its a 93 the MAF is outta the question, I had a similar problem in my 86 Berlinetta (2.8L) turned out the fuel pump was bad, I would definaltly check the fuel pressure, im not sure what the pressure is supposed to be off the top of my head...but im sure someone here does.
Fullagar
Old Nov 10, 2003 | 04:15 PM
Ronin's Avatar
It was the cat. After I gutted it the car ran good. I am putting on another cat I have that has low miles. Thank you to all that responded.
liamcg97
Nov 25, 2019 05:55 PM
30thZ4C
Dec 26, 2014 05:09 PM
Dec 23, 2014 07:52 AM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
