Whats wrong with my car?
Old Oct 24, 2004 | 07:53 PM
Evilfrog's Avatar
Just got it back together. It miss fires and overheats. Also, the alternator isn't charging the battery. Do you think that it can cause both of these problems(I have an electric water pump). Or could the missfire be because I just installed headers and still have the stock 02s? And maybe something like a bad thermo causing the overheating.
Old Oct 25, 2004 | 08:04 PM
slopokrodrigez's Avatar
Re: Whats wrong with my car?
You probably have a wire problem. Like burnt or on the wrong plug or loose. Look for that first before doing anything else. Chances are once the engine is running correctly at the right speed, it will begin charging like usual.
Old Oct 25, 2004 | 09:41 PM
Alvin@pcmforless.com's Avatar
I would double check every ground.
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
