Whats wrong with my car!
Old Apr 22, 2004 | 10:47 AM
CamaroUK's Avatar
Ok I've got a 95 Camaro M6, its recently developed this starting problem, I turn the key, it fires up and then dies. I do this a few times until it starts but even then its running like its on 4 cylinders. Its worse when its a cold start.
The revs are stuck at 7-800 rpm and giving it a bit of throttle makes the engine and whole car shake about.
Although after about a minute, it clears and then idles and runs fine
Please dont tell me its the opti
Anyone care to throw a few suggestions as to whats going wrong? is this a common problem?
This is becoming a real problem lately
Old Apr 22, 2004 | 11:01 AM
faded93bird's Avatar
Sounds like something is leaking in the fuel system (injectors, fuel pressure regulator)
Dose it puff lots of black smoke on start up?
Old Apr 22, 2004 | 02:24 PM
CamaroUK's Avatar
Theres no smoke at all when I start it up. Is it possible for the fuel lines to get an airlock?
Also does each bank of cylinders have a seperate fuel feed to the fuel rails? I mean is it feasible that one half of the engine is recieving very little or no fuel on start up due to an air/vapour lock?
Old Apr 22, 2004 | 02:27 PM
CamaroUK's Avatar
Can I safely rule out the opti The car runs fine when it gets over the problem.
Old Apr 22, 2004 | 02:35 PM
Could also be the fuel pump dieing.
You should check your pressure and see if it bleeds down or is low
Old Apr 22, 2004 | 02:41 PM
CamaroUK's Avatar
If it were the pump failing would it not affect the regular driving and acceleration?
Is there an easy way of checking the fuel pressure without taking it to a dealer? I dont have much in the way of tools
Old Apr 22, 2004 | 05:56 PM
kmkommes's Avatar
WHen I first transplanted my 94 LT1 into my 94 4x4 s-10 it ran like total crap. It drove but was super slow. It turned out that I didnt have power on half the injectors. I think in your car there should be two seperate fuses for the inejctors, I would check those. The injectors still fire but they fire at the wrong time and the wrong amount I believe. After fixing the power problem my truck screamed, made me very happy.
Old Apr 22, 2004 | 06:02 PM
disco192's Avatar
How warm does it need to get? Does it start running better once it goes into closed loop?
Old Apr 24, 2004 | 12:20 PM
ichabod's Avatar
CamaroUK, did you ever get this fixed?
Old Apr 24, 2004 | 12:23 PM
GreenDemon's Avatar
My car has also done this, it seems it only did it in cold weather though.
It ran really rough, and less than a minute later it would cut over suddenly and run perfectly. I can't figure out why it did it though.
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
