whats wrong? (bad mpg)
Old Aug 18, 2007 | 06:32 PM
94redandblackz's Avatar
i have a 94 z28 pretty much stock w/ magnaflow cb and k&n and i have only got 12-13 mpg ever since i got it and over that time i have changed bad o2 sensors, cleaned MAF, changed fuel filter but it still really hasnt changed at all, HELP!!
Old Aug 18, 2007 | 06:53 PM
bump, and it is a 6 speed
Old Aug 18, 2007 | 07:56 PM
Z28LT1_Just_Nasty's Avatar
Ryan's Guide to MPG
Just making a general list, pick and choose what you have or have not done and go from there.
Plugs
Wires
Cap & Rotor
Clean Air Filter (I see you have a CAI, they can be washed depending on brand)
Fuel Filter
O2's
Check for low tire pressure
Clean MAF
Change Oil (As oil is broken down through driving it will slowly eat away at your fuel economy, as does thicker oils)
Check for Exhaust Leaks
Driver mod
If I remember anything else I'll add it.
Old Aug 19, 2007 | 01:19 AM
i actually do have a small exhaust leak i hear while the cars running and dont really beat on it often. But i did get some champion plugs not too long ago and some wires so i got those. The only thing i havent replaced is the cap and rotor, do you think i should? .... do you think an exhaust leak would take off 2-3 mpg? and the car runs great
Old Aug 19, 2007 | 06:30 AM
solarofthesix
Guest
Posts: n/a
man I have the hotcam kit and drive a lil fast from time to time and my gasmilage is usually a little better than that. check your injectors. Another hting not listed, that seems to make a few more miles into the tank is a PCV Valve. Didnt see anyone mention that.
Old Aug 19, 2007 | 12:14 PM
Bingo.
An exhaust leak will lead to an incorrect lean reading on the o2's. The PCM will compensate by dumping fuel at the problem. Also possible false knock retard won't help your fuel economy either.
Old Aug 19, 2007 | 01:59 PM
alright thanks for the replies, i knew the exhaust leak was one of the reasons... how do i know if the injectors are bad? and ill look into the pcv valve and the knock retard
Old Aug 19, 2007 | 03:10 PM
speed_demon24's Avatar
You still havent said what kind of driving you are doing and how hard you are driving it to get that gas millage.
Old Aug 19, 2007 | 11:21 PM
i drive 3000 rpms or less when i drive regular then i prolly get on it about once or twice a tank.... idk but today my car started running like **** and rattles at idle and feels like lost power, when i rev it sounds fine and revs normal but drivin is rough and feels like a huge exhaust leak, can someone help!??
Old Aug 20, 2007 | 12:00 PM
multicar's Avatar
Sounds like not only an exhaust leak but a vaccuum leak as well.
Doug
Old Aug 20, 2007 | 10:13 PM
zx1216's Avatar
huh, that sucks, i beat the **** out of my cc306 cammed car with mixed stop/go and hw and got 19.5 mpg with it :-)
Magenta_Hearts
Mar 22, 2015 03:36 PM
grgguy
17
Feb 23, 2015 07:57 PM
Deadbolt24
Jan 19, 2015 01:29 PM
Amshnock
14
Jan 18, 2015 11:47 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
