What's up with the one wheel peel?
I just got back from the track and noticed that sometimes when i was doing a burnout that one wheel was spinning unstead of both.....when it would do this the car would wheel hop bad off of the line.....i had one burnout that did both of them and it didn't wheel hop....Is my diff. going out? how can you fix this?
your diff is on its way out id say. The rear only turns one wheel when your turning. The only reason it does that is because when your cornering both wheels dont turn the same speed. It should be spinning both during a burnout.
I'll add this, since it looks like you're about to spend a lot of money. When I first got my Z I had a lot of problems with the diff. It was making some horid, I mean absolutely awful noises while going around tight corners and it would randomnly engage and disengage (i.e. one wheel peel) I changed out the fluid and put in the limited slip additive and I've had 10,000 miles of absolutely trouble free operation. I launch on Nittos all the time at the track. This is a 168,000 mile diff, that I want to blow up so I can upgrade and it has been wonderful.
Change the fluid first, spend the $30 tops it'll cost you and see what happens.
That sucks....the fluid that is in it doesn't have but about 500 miles on it....maybe....i guess i only need to replace the diff? I might just go get one of the knock off's that slp sells...
Michael
Michael
Michael
Michael
no, its not. Everytime you go around a curve the clutches are working to prevent wheel hop and keep traction. You have probably already fried your diff because of not having it in there. If you can get a take off diff from SLP for $100 then thats how I would go.
