Whats this trouble code mean?
When the PCM is in closed loop, the PCM responds to the O2 sensor signal by constantly switching the fuel calcs to run very slightly richer (14.65:1) than stoichiometric (14.7:1) and slightly leaner (14.75:1) than stoichiometric. That seems to allow the cat(s) to work best. In response, the O2 sensors should be switching rapidly back and forth between rich (8xxmV) to lean (1XXmV). Your pre-cat sensor on the drivers side isn't responding. Its just sitting in one place and putting out a relatively fixed mV signal. Sign of a lazy sensor.
Switch the right and left pre-cat sensors and see if the problem follows the sensor (sensor problem) or stays on the driver's side (wiring, ground, etc.).
armedtrigger
Feb 24, 2015 08:30 PM
