Whats the thread size on the factory T-56 shifter?
yes 16mm x 1.5
i remember because i drilled out a pool que ball and pressed a metal fitting into it and tapped the inside of the metal fitting to 16mm X 1.5, works like a charm, and i have a shift ball that i get a good solid grip on since its a little larger than ordinary shift *****
james007moore
Jan 1, 2016 01:14 PM
