whats the stockbottomend lt1 record!
Old Aug 11, 2006 | 09:25 AM
red96z's Avatar
im going to be fast on the gas if it holds up and was wondering what the record is or at least the top5???? quarter mile only!
Old Aug 11, 2006 | 09:37 AM
Grims's Avatar
Re: whats the stockbottomend lt1 record!
HP or ET?
Old Aug 11, 2006 | 09:38 AM
Javier97Z28's Avatar
Moderator
Originally Posted by TA-Body
HP or ET?
He said quarter mile only didn't he?
wrd1972's Avatar
I am pretty sure I remember seeing somthing way back where someone hit a high 9's or low 10's. Those engines had to be on the razors edge of destruction. I will look for the post.
Old Aug 11, 2006 | 09:42 AM
Daniel6718's Avatar
i think it was a high 9...
Old Aug 11, 2006 | 10:10 AM
Grims's Avatar
Maybe he meant highest HP, for 1/4th use only
Old Aug 11, 2006 | 10:17 AM
Zigroid's Avatar
http://web.camaross.com/forums/showthread.php?t=305819
FASTEST STOCK BOTTOM END LT1
"BigkevC5"(car now owned by East Coast Supercharging)
1997 Camaro Z28
350ci LT1 w/ LT1 ported heads, Cam, boltons, 150 shot
1/4: 9.75 at 139
JucinGTA
1997 Camaro Z28
with a 200 shot/fogger, cutting 1.43-44s on a 10bolt, Home Ported heads flowing 250cfm, Comps Nitrous Cam, Stock Shortblock, Stock 4L60E with a Shift kit.
1/4:10.44 @129
^^^ that man has *****
FASTEST INTERNALLY STOCK LT1
Craig Miller/ Madman Racing
1996 Trans Am
hooker longtubes, mufflex exhaust, Moroso cold air, and a 52mm t/b. th400 with brake, 9" rear end. 150 dry NOS kit. Madman Suspension. Stock interior and all accessories.
1/4: 10.86 @120
60 ft: 1.38
Mike Alford "Mike Comp T/A #57"
1995 Comp T/A #57
auto, longtubes, elect. WP, 52mm TB, QA1 & Spohn suspension, 150 shot, 3800lb raceweight
1/4: 10.89 @ 128mph
1/8: 6.89 @ 100mph
60ft: 1.47
FASTEST CAM ONLY LT1
Frank95z
1995 Z28, stockheads ,A4,52TB, cold air,hooker longtube headers, Joe O custom grind cam, 1.6rr,Strange 12bolt,QT Pros, Vig3200, 3325lbs
1/4: 11.273 at 118.90
FASTEST HEADS/CAM LT1
James Eddy
stock ported heads and intake ,hyd.
1/4: 10.88 @ 122.81
1/8 6.90 @ 99.08
Old Aug 11, 2006 | 03:00 PM
neil350's Avatar
A lot of that is having a car thats light and can hook hard, I know both buys that had/held the LS1 stock short block records, Mike went 9.6s in his 98 Z28, car only ran 117 on motor, wasnt any thing crazy, just had a really good suspension, was light and could hook on a big shot of gas. The h/c set up on his car was circa 2001 MTI as it came off another friend of mines car. Dan had it next with a 9.6, his car also wasnt any thing great on motor, heads were ok, decent cam, but it was gutted worse than a theft recovery and could hook stupid. The thing is both cars far as on motor went, werent the pincacle of h/c set ups, nothing like whats out on the LS1s now. Some thing like an LE3 on gas in a very light car, with a well tunned and working suspenson would do the trick. Both Dan and Mikes car ran TH350 with 12 bolts. A lot of keeping the motor together for both those cars was the amount of tunning that went in to them, both buys are also Techs.
ChrisFrez
Jan 25, 2015 08:06 AM
Jazsun
Dec 29, 2014 12:14 PM
FilledWithFurySS
Sep 14, 2002 07:32 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
