What's the stock gears in 93 a?
Old Mar 3, 2009 | 09:51 PM
Robwhartlt1's Avatar
Eu guys I have 93 a4 what's the stock gear in this car? And how do I know if it's not stock? Thanks for all info.
Old Mar 3, 2009 | 10:04 PM
Bersaglieri's Avatar
Access to 1st 3.23
Access only to 2nd 2.73
-Dustin-
Old Mar 3, 2009 | 10:17 PM
Ok I have no idea what that means. Sorry man
Old Mar 3, 2009 | 10:20 PM
mrmint69's Avatar
On my 94 the optional upgrade was 3:23 gears. I think the came with 2:73 for all the rest. The door code will tell you what ones came with the car. If you speedo is off and no one calibrated it for different gears then you have the factory ones.
Old Mar 3, 2009 | 10:25 PM
If your gear shift goes to 1st, 3.23, if it only goes to 2nd, 2.73.
-Dustin-
Old Mar 3, 2009 | 10:30 PM
ok I have 1st in my car. Is that good or should I get better ones
Old Mar 3, 2009 | 10:35 PM
mrmint69's Avatar
3:73 is the recommended ones for the A4. I did it and love them. The 4:10 are nice but don't do well on long high speed trips.
Old Mar 3, 2009 | 10:42 PM
3.23 is a pretty good over all gear. I'd keep those till you get more mods.
-Dustin-
Old Mar 3, 2009 | 10:46 PM
Check the build code tag:
GU2 = 2.73:1
GU5 = 3.23:1
Note that the ratios are not expressed as 2:73, 3:23, 3:73, 4:10, etc.
What ealse should I do I have ran out of things I know to what other mode do you think?
Old Mar 3, 2009 | 11:35 PM
Sorry didnt see your mod list. If you can get traction, some gears wouldnt hurt. Might be time to think about a converter upgrade also.
-Dustin-
HectorM52
Jul 30, 2017 11:46 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ddr698
Jan 9, 2015 10:05 AM
cmdeshon
Dec 27, 2014 10:06 AM
