Whats the smallest I can fit on 17x11?
Old Feb 20, 2003 | 10:36 AM
  #16
jimlab's Avatar
Originally posted by 25thAnnTA
Im confused, some shops wont mount a 315 on a 11' rim? Didnt the corvette come stock with this setup? How is a 315 on an 11' rim considered dangerous? I mounted this setup on my TA and I'm VERY pleased with how it looks.
The ZR1 did, and I'm sure it looks great, but try the test I mentioned above (powerbrake) and see what your actual contact patch looks like. It should be very evenly black and squared off from side to side. If it's faint on one side or the other, you probably need an alignment adjustment. If it's faint or non-existent in the center, you went too big on the tire.
Old Feb 20, 2003 | 10:40 AM
  #17
25thAnnTA's Avatar
What? and burn up the new 315's? I'll give it a try. im pretty sure though that my traction hasnt changed a great deal from the stock 245/16's that were on it. Im planning on putting some drag radials on the 16's for track use, the 315's are really just show.
Old Feb 20, 2003 | 11:05 AM
  #18
jimlab's Avatar
Well, you don't need a block-long burnout. A few feet will tell you all you need to know.
Good deal.
Old Feb 20, 2003 | 12:58 PM
  #19
RedRyder518's Avatar
Well, like I said, temporairly I will have the 275's on the 11's. Is it bad that if I want to rotate the tires, to have the tire place dismount the tires, and rotate them, then remount them?
Old Feb 20, 2003 | 01:14 PM
  #20
Dr.Mudge's Avatar
No, it just costs more than rotating wheels, you can pull the tires though.
Old Feb 20, 2003 | 01:26 PM
  #21
Pull the tires??
Old Feb 20, 2003 | 02:14 PM
  #22
Dr.Mudge's Avatar
If your dismounting a tire to put it on another wheel, thats "pulling" a tire off
Old Feb 20, 2003 | 02:31 PM
  #23
95 Z/28 LT1's Avatar
Super Moderator
So what's the ideal tire size for a 17 x 9.5 rim?
Old Feb 20, 2003 | 02:41 PM
  #24
25thAnnTA's Avatar
im thinkin the 285 is pretty sweet, my brother in law just put on a set and they look good. now traction wise????? dont really know.
Old Feb 20, 2003 | 08:02 PM
  #25
jimlab's Avatar
The less you have them worked on, the better off you'll be.
Every time you remove a tire or install a tire, you run the risk of damage to both the tire bead and the rim. If you didn't buy either one from the shop doing the labor, you can almost bet they're not going to be taking absolute care not to scratch or gouge anything up. Les Schwab is famous for that... hold your hand, give you coffee, and mount your tires with kid gloves the first time, then hand-torque your lug nuts to perfection. But come in to have them changed around and they scratch the rims, drop them on the ground, and use an impact wrench on the lug nuts because you didn't buy anything new this time around.
Old Feb 21, 2003 | 08:02 AM
  #26
Super Moderator
TTT
Old Feb 21, 2003 | 09:31 AM
  #27
Ya, I think you have a point there. The 11's would look sweet on the rear, but I think it will either be too much trouble or too much money for me. Eh well, i guess it will be 9.5's all the way around... By the way, the rims that Jegs is selling now(Detroit Replicas), are they any good? They are pretty cheep in price($235 i think) for chrome...
Old Feb 21, 2003 | 11:32 PM
  #28
muraoka's Avatar
i have 17x9.5 around but i ordered the rear with a 38mm offset
puts the tire (285 last year 315 this year)right at the edge of the fender.by the way its all looks 16 inch drs for the track.
matt
Old Feb 22, 2003 | 03:34 PM
  #29
Black bow tie's Avatar
I like to run my tires sqaure to the rim (bead), which means the tread width is the same as the rim width, or as close as possible. Go to tirerack.com and look at different tire sizes, also look at the tire "specs" which has the actual tire measurements, and will also state what rim widths each tire can use. Also note that different tire brands and models measure differently in the same size. The other thing to consider is cost, the 315's are REALLY spendy, and there are fewer choices. I would rather have the 17x9's with a top notch 275/40-17 than the 17x11's with el-cheapo's.
bowtieboy95
Jul 1, 2015 06:49 AM
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Ken Cemo
Parts Wanted
Jan 28, 2015 09:04 AM
Camaro_Eric
Aug 8, 2002 12:21 PM
