what's this? (pic inside...)
Old Nov 22, 2004 | 09:30 PM
dmoor88's Avatar
This piece was hooked up to the air pump that I removed.
What is it?
Old Nov 22, 2004 | 10:13 PM
96m6lt1's Avatar
Re: what's this? (pic inside...)
looks like the EGR selonoid
Old Nov 22, 2004 | 10:17 PM
dmoor88's Avatar
I pulled the hookup that's on the intake and it's drawing a suction. I removed the piece Im holding in my hand and simply stopped the end up with a stopper and tucked the tube. Any ideas on what to do with it?
Old Nov 22, 2004 | 10:29 PM
zx1216's Avatar
yea, thats the egr selonoid, i did the same as you did, just caped them off.
Old Nov 22, 2004 | 10:31 PM
dmoor88's Avatar
okay. thanks!
Old Nov 22, 2004 | 10:53 PM
Doesn't look like an EGR solenoid to me. If it came off with the AIR system, it is probably a bleed valve for it. You won't need it with the AIR system gone.
Old Nov 22, 2004 | 10:55 PM
Bryan Smith's Avatar
Yeah the EGR solenoid didnt hook up to the air pump. That's the bleeder. I just pulled it all.
Old Nov 22, 2004 | 10:59 PM
dmoor88's Avatar
What about the vacuum?
Old Nov 22, 2004 | 11:01 PM
put a cap over it. (intake side)
Old Nov 22, 2004 | 11:03 PM
dmoor88's Avatar
do just remove the whole tube from the intake and cap that end? it won't hurt anything?
Old Nov 22, 2004 | 11:04 PM
Nope. If/when you remove your EGR soleniod you'll have to do it for that one too.
Old Nov 23, 2004 | 04:02 AM
Dave89IROC's Avatar
on a 95, I would have to say that is what the air pump recall installed
Old Nov 23, 2004 | 11:17 AM
dmoor88's Avatar
huh?
Old Nov 23, 2004 | 11:24 AM
trans9_5am's Avatar
There was a recall on the AIR pump for 95's and when you (or whoever took it in) to fulfill the recall requirements, they had to install this valve on. Just remove it and either cap it off or plug it off. I took one of the plugs out of my old heads and then removed the one out of the intake and replaced it with the plug that was in the head. If you dont want to do this, just cap it off with a vaccum cap.
Brandon
Henson071
Dec 30, 2015 09:55 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
meissen
Aug 11, 2015 06:05 AM
cjamen
Jul 27, 2015 12:48 PM
cmsmith
Jul 10, 2015 07:19 PM
