What's this? Opti?
Old Apr 13, 2004 | 10:32 PM
rlax31's Avatar
What's this? Opti?
Lately the 97 (45k miles) has been having some problems. It began with just the car stumbling a bit at startup. Then it got bad when I went to start the car and got nothing. I jiggled the battery cable a bit, started right up. Also at low speeds I'll loose power stearing, but I thought that just might be the PS pump.
It was ok for a couple days, then it happend again. Another jiggle, started up. This has become more and more frequent, so I took the battery cable off, doesn't seem to be any corrotion, connected it up tight. I went to start the car, and it dies. So I started it up and gave it a bit of gas to keep it going, but it will pulse at idle untill it finally shuts off after a few seconds.
Is it Opti? what else could it be? Could it cause the power stearing problem?
I'm going to mess with it a little more tomorrow, if nothing I'm taking it in on the extended warrenty.
Thanks for your help.
Old Apr 13, 2004 | 10:35 PM
Red96Lt1's Avatar
Man if you got a waranty, I would just do that. Other than that, I don't know a easy solution.
Old Apr 13, 2004 | 11:21 PM
If idle gets low enough, I'm sure it would affect the PS. If you have a warranty, use it.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
