What's the normal alternator voltage for an LT1?
Old Feb 24, 2009 | 01:46 PM
flexus's Avatar
My indicator keeps showing 13-14v values all the time. It should be around 12V right? My indication shows something may be wrong or?
I'm asking because i've burned through 4 low beam sealed beams in the last year and they are not that cheap. I figure they cost that much and are SEALED especially to last longer... It's getting ridiculous and I can't find anything to blame except the frigging high voltage
Old Feb 24, 2009 | 01:53 PM
drptop70ss's Avatar
13v-14v is normal. If it reads 12v your charging system is not working.
Old Feb 24, 2009 | 01:57 PM
ayers1967's Avatar
It takes 13.9 to 14.2 volts to keep the 12 volt battery charged.
Old Feb 24, 2009 | 01:58 PM
RamAir95TA's Avatar
Yep - if it reads 12V all the time you're running off of the battery.
Old Feb 24, 2009 | 02:01 PM
flexus's Avatar
Then what the *#%~ keeps burning my low beams... it costs me 70$ each time they decide to get burned out (with shipping to europe)
Old Feb 24, 2009 | 02:23 PM
8cylinders>4's Avatar
i cant tell you what is burning out your headlights but i feel your pain
when its cold here (-20 - 0 degrees F) when i start my car it will show well over 15 volts and i burn them out every once in a while too
little hint for ya the next time one of those sealed beams burn out, buy yourself regular 9006's for the low beams and silicone them in the existing housings it's about a third of the price around here
Gtpguy
Jan 26, 2015 04:50 PM
edman
Jan 22, 2015 02:45 PM
HectorM52
Jan 16, 2015 10:21 AM
pete53
Dec 9, 2014 07:31 AM
JSK333
Sep 9, 2002 10:33 PM
