Whats this noise when its shifts?
Old Jun 23, 2003 | 12:48 AM
CrippleFightin's Avatar
Arrow Whats this noise when its shifts?
When I floor it and my car shifts from 1st to 2nd and occasionally 2nd to 3rd, it makes a short of squeek noise. Almost as if you slam a pop can on the ground when its closed and all the pressure is released.
Old Jun 23, 2003 | 12:55 AM
jasons93z's Avatar
your tranny is going out and your screwed, be prepared to dish out 2k..............................
J/K
Sounds to me like your breaking your tires loose, explain the noise a little better. When i had my 93 a4 it would chirp the tires on the 1-2 shift and on soft pavement it would do it on the 2-3 shift.
Old Jun 23, 2003 | 12:57 AM
Blue96z28's Avatar
could be a bad/weakened tranny mount/torque arm mount? i had my tranny mount go, but it was more of a pop on the shifts....does it do it only when it shifts? or does it do it sometimes when you accelerate hard from a stop and the weight transfers?
Old Jun 23, 2003 | 01:00 AM
Well I replaced the tranny mount not too long ago. No clunk when I gun it. The noise has been happening since I got the car last October. If it was going to go out would it have done it by now?
Old Jun 23, 2003 | 01:01 AM
jasons93z's Avatar
if its the tranny mount you will feel a thumb on the floor board
Old Jun 23, 2003 | 01:03 AM
jasons93z's Avatar
it really doesnt sound like its going out to me, and ive had plenty trannys go out on me.
Old Jun 23, 2003 | 01:04 AM
Oh I know all about the tranny mount. I am just curouis about the squeek noise when it shifts. Its not the tranny mount. Anyone got any other idea? Please tell me its not gonna take a crap on me.
I swear I will burn the car and take the insurance money. I hate the 4L60E!!
Old Jun 23, 2003 | 01:09 AM
jasons93z's Avatar
is it just at wot? are you sure its not just the tires chirping? Does it bounce off the rev limiter at wot(that is usually a sure sign that its slipping)
Old Jun 23, 2003 | 01:12 AM
Yes just at WOT. Never any other time. Pretty sure its not the tires, its a little different sound than that. They are very bald too so it might make em chirp a little different, but pretty sure thats not it. It shifts a little hard, but not too bad and doesnt bounce of the limiter either.
Old Jun 23, 2003 | 01:17 AM
jasons93z's Avatar
like i said, i dont think you have to worry about the tranny, it sounds like something else.
Old Jun 23, 2003 | 01:29 AM
Thanks for the help. I sure hope that thing doesn't break. I DAMN sure can't afford to fix it right now. Thanks again. Atleast I have a little piece of mind.
Old Jun 23, 2003 | 03:52 AM
SilvercamZ28's Avatar
I can almost garuntee it's your serpintine belt.. yeah it may not look worn.. but I had the same problem... I cleaned off the belt (wiped it down) then I used rubbing alcohol on the pylley surfaces with atooth brush... worked like a charm and it never did it again..... If it's a high pitch squeal then that's what it is... just give her a good cleaning and she should be good to go!
Old Jun 23, 2003 | 03:54 AM
I can almost garuntee it's your serpintine belt.. yeah it may not look worn.. but I had the same problem.. the belt can't grip enoough during the shift for some reason so it drags on a pulley causing the squeal I don't know which one so I cleaned them all... I cleaned off the belt (wiped it down) then I used rubbing alcohol on the pulley surfaces with a tooth brush to get in all of the crevaces...then I wiped them all down again with a towel worked like a charm and it never did it again..... If it's a high pitch squeal then that's what it is... just give her a good cleaning and she should be good to go!
Old Jun 23, 2003 | 07:53 AM
bruecksteve's Avatar
It's your belt. My does it bad now that I've installed a rebuilt A4 and Vigilante TC. I've read something about sanding some of the pulleys to roughen them up. I have a brand new belt. It could also be the tensioner is getting weak.
Damn, everytime I read this I have to correct my typing!
Old Jun 23, 2003 | 08:34 AM
I'll try mine tonight and let you know if it fixes it.
Henson071
Sep 18, 2015 04:01 PM
Cam's maro
Aug 11, 2015 07:45 AM
colts0455
13
Aug 7, 2015 09:15 PM
GT what?
Jul 14, 2015 10:17 PM
colts0455
Jul 7, 2015 07:19 PM
