Whats next (mods)?
Old Sep 3, 2003 | 01:50 PM
zx1216's Avatar
Whats next (mods)?
Hey, like the subject says what should i do next? I know i should do long tubes next but i just started college so i don't have the time/money to install them untill this spring. What else can i do for around/under $200? Any ideas?
Nick
Old Sep 3, 2003 | 01:59 PM
BlakeW5's Avatar
You could do some suspension stuff (some), buy a cutout w/qtec, or if you have a job, just save for the headers. They'll get you the biggest gain over anything you could do now.
americanmusscle's Avatar
Cut-out maybe or some sway bars
Old Sep 3, 2003 | 02:03 PM
IrocManiac's Avatar
Perhaps a strut tower brace and subframe connectors?
Old Sep 3, 2003 | 02:32 PM
street demon2k3's Avatar
i say get a cutout($35), and since you already got the cai do the ram air mod, this might help a little bit. i am going to college also so i need to keep working for books and not more mods try alot of free mods in the mean time.
Old Sep 3, 2003 | 02:56 PM
BlakeW5's Avatar
You could also put in a lower temp. thermo and some coolant additive (Water Wetter or Purple Ice). I know how it is to be in college and have no money. Luckily, I get some extra through my scholarship. I need to get a job so I can get back into the mod war .
Old Sep 3, 2003 | 03:01 PM
IrocManiac's Avatar
I disagree with the low temp thermostat...I haven't had a use for one here in OK sure my temp goes up some when its 105* but as long as I'm moving its down below the 210 mark all the time...living that far north you'd definately want the stocker back in come winter time so unless you wanna switch every 6 months (which isn't hard) I'd keep the stocker in there its plenty adequate for daily driving and there is such a thing as running too cool believe it or not.
Old Sep 3, 2003 | 03:21 PM
dont know about that 105* thing but down here in texas its about the same temp but the humidity is a b!tch. i just replaced my radiator a month ago and my a/c is messed up also. but if you dont want the stat just rig up a fan switch. the switch really helps here in tx when there is alot of traffic, before, the switch kept my temp went to 190-200 in traffic and now it stays at 160-170 w/stat and switch.
Old Sep 3, 2003 | 03:36 PM
KwikistZ's Avatar
173k dayum! Maybe you should just save in case somthin happens Just learn how to drive that M6 to the limits, that'll improve your time By the time you do that, you could have enough for the LT's
Maybe...
Old Sep 3, 2003 | 03:54 PM
zx1216's Avatar
yea 173 k, all driven by my 50 yr old uncle, so it was babied it's whole life, although i do have about 3k in the bank in case something would happen. I'm gonna wait to do the big mods(lt's,clutch,rebuild?) this spring in case i also need money for school related items. I just wanted to do a few thing while it is still warm here in wi, which is not for too much longer. I'm going to the track next weekend so i'll see what kind of times i can rip off with 173k and 150k on the stock clutch
Old Sep 3, 2003 | 04:00 PM
zx1216's Avatar
If i was to do the sfc's, which ones do you guys recomend? Are the bolt in ones as strong as the weld in when they are installed? I would like to install them myself but i don't have a welder.
Old Sep 3, 2003 | 04:04 PM
RedPhenx's Avatar
I would get weld-in, I have heard that the bolt holes can elongate over time
Old Sep 3, 2003 | 04:55 PM
zx1216's Avatar
Any thing else? What sfc's should i get?
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
karpetcm
Sep 15, 2015 11:07 AM
CamaroSS30thAnn
Sep 8, 2015 04:43 PM
CARiD
Jul 7, 2015 08:19 AM
