whats needed to rebuild calipers?
Old Nov 25, 2003 | 11:46 AM
anasazi's Avatar
my car pulls to the right while driving and pulls to the left while braking. i think my passenger caliper is binding.
what is needed to rebuild the caliper? the guy at discount auto handed me a bag with one single gasket in it, and i can't believe thats the only thing that is replaced.
and how do you do it?
Old Nov 25, 2003 | 01:13 PM
OldSStroker's Avatar
Check with a GM parts department. There should be a seal and a boot (both rubber-like material) and perhaps gaskets.
Make sure you use new Caliper Bolts and sleeves and their associated bushings. There is a possibility those are the real culprits and the caliper is fine. You can replace them and the pads, of course, without disconnecting the caliper from the hydraulic line.
If you rebuild the calipers (or buy rebuilt ones), flush the whole system with new fluid and bleed the master cylinder first then each wheel cylinder.
You may also need rotors.
My $.02
Old Nov 25, 2003 | 03:46 PM
96z's Avatar
96z
Listen to what OldSStroker said....
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
maybe2fast
Feb 5, 2015 05:14 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
