whats needed for intake manifold leak fix
Old Dec 25, 2003 | 03:21 PM
WhiteThunderZ28's Avatar
Hi I have a 94 Z28 just so you know and I have the Intake Manifold leak... The leak is coming from the front and is getting over everything...
Can anyone please tell me what materials and items i would need to fix this problem, also i would like to make it never leak again.
Thanks for the help
Old Dec 25, 2003 | 05:39 PM
$hawn's Avatar
Mainly get fel pro gasket set #MS95580, some ulta black rtv, rags, common tools, I'm sure there are a few step by step guides on how to do it.
Old Dec 25, 2003 | 06:19 PM
Soccerbum21's Avatar
being someone who just got down doing the intake manifold gasket, i would highly recommendlink to guide
i didnt remove the fuel lines from the fuel rail. i just moved it to the side when i was working. Romoving it prolly would have made it easier, but i didnt want to get fuel everywhere.
this guide helped me a lot.
i just did my gasket last weekend. It took me 2 days. I didnt work as feverishly as i should have though. Be prepared to come out of the deal with scraped knuckles and dont forget to unplug the EGR selenoid on the next to last bolt on the dirvers side, i broke those wires cuz i forgot about it being there.
take some engine degreaser and take the time to clean everything up really well while you have it all off
paint it if you want to, mine is LT4 red, but my car is also red so it looks nice.
make a really thick bead along the ridges and dont forget to put the RTV along the gasket on boith sides, the gasket is not a "dry gasket" and even if it was, you should put RTV on both sides anyways
hope this helps, this board was really helpful when i did mine so i am returning the favor.
Old Dec 27, 2003 | 01:15 AM
OBE1 95Z28's Avatar
Are you positive it's the intake that's leaking from the front? A common leak on these cars is the seal around the waterpump drive gear. I'd add dye to the oil and check it with a blacklight before yanking off the intake.
Old Dec 27, 2003 | 01:22 AM
S.J.S.'s Avatar
I agree with OBE1. Most of the the time...in fact....all the ones I've heard of are intake leaks coming from the rear of the engine. I personally have never heard of any leaking from the front. My Opti seal is leaking right now and getting oil all over and its only a couple drips. Just changed them all too. Kinda sucks.
Old Dec 27, 2003 | 01:28 AM
KWIK WS6's Avatar
From: Southern California, where do YOU live mutha****a?
The right stuff You can find it at kragen or auto zone
Old Dec 27, 2003 | 12:24 PM
Well the oil is getting all over the opti and the pulley... I also found oil on my coil but that might just be from theoil hitting the pulley, so basicly oil is all over the bottom part of the engine
ModdedNerd
Dec 14, 2014 10:28 AM
Elcojoe
Nov 17, 2014 10:27 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
mjcent922
Jul 27, 2002 12:42 PM
