What's needed to change a 93 to 94 PCM?
Old Sep 13, 2003 | 10:43 AM
BlackDog's Avatar
First off can it be done?
Second, what wiring harness to use and what else to look for.
I read a couple of posts as to what is needed to tune a 93 but, it seems to me it is a hassle to keep removing the chip to program it.
Scott
Old Sep 13, 2003 | 11:49 AM
The key differences are the sequential (94+) vs. batch fire (93) injectors, the presence of a mass air sensor (94+) and the electronic 4L60E control (94+).
You need a harness with provision for 8 individual injector signals (your 93 just has one wire for left bank and one wire for right), and the MAF sensor - of course you also need to get the sensor. If you have a 4L60 (93) you need to either delete the A4 control functions, or install simulators to make the PCM think its a 4L60E.
If your 93 is a T56, the new (94+) harness will need the resistor to eliminate the skip shift code.
You will also have to change the O2 sensors.... the 93 uses a single wire (to the ECM) sensor, with no heaters. 94+ uses a 4-wire sensor, with 2 wires to the PCM and two for the heaters.
There may also be an issue with the pulse rate out of the VSS.
You would be best off with a 94 or 95 harness, since a 96+ harness would have a ton of extraneous connections for OBD-II detection devices that don't exist on the earlier models.
Old Sep 13, 2003 | 12:39 PM
BlackDog's Avatar
What issue do you thing I'd run into. Maybe replace the sensor with a 94?
Thanks Fred
Scott
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
FASTFATBOY
Jul 6, 2002 01:02 AM
